Airborne laser cannon
Nyati13
785
Originally posted by: legoman666
Originally posted by: crystal
Originally posted by: KB
And what happens when it crashes? 40,000 lbs of chemicals spew into the air? Sounds cool but scary.
I don't think we will see a portable version anytime soon.
I think the whole thing weight 40,000 lbs. I assume you considered these chemicals..
2. Heat Up the Laser
In a fraction of a second, chlorine gas mixes with hydrogen peroxide. The resulting chemical reaction creates highly energetic oxygen molecules. Pressurized nitrogen pushes the oxygen through a fine mist of iodine, transferring the oxygen?s energy to iodine molecules, which shed it in the form of intense light.
yea we wouldnt want any oxygen or nitrogen in the air.
Your forgetting the chlorine, iodine, and hydrogen peroxide........
legoman666
3,628
shhh. You're ruining my argument.
Nyati13
785
Originally posted by: DisgruntledVirus
shark mountable?
Not quite, but we're getting there.
Hmm... laser at 5 miles or missile at 500 miles...
Laser that costs only a few thousand to run or a missle that costs $100,000+ ?
The only expenses with the laser are the chemicals which are not too expensive (Chlorine, O2, and Iodine are all fairly common and not massively expensive). A missile OTOH is very expensive in the 6-7 figure range. The laser is much cheaper and safer for troops on the ground in a combat zone IMHO. Missiles have their uses though, and for a stand off and attack situation I will take a missile any day (cruise missile FTW)
With a range of only 5 miles, this aircraft could only be deployed in completely dominated airspace. Any semi-modern antiaircraft system can hit an aircraft at 5 miles. In contested airspace, a stand off missile is still the better choice.
novasatori
3,851
shark mountable?
I believe if I remember the previous reports right, each time they power up that laser it costs on the order of a few million $ per shot. Remember, this is military we're talking about.
I worked on the program summer of 06 and it won't be near that much. Virus is a lot closer
also: truck-mounted laser
I think he is thinking of the ABM laser that is being put on the 747 in regards to the mullion dollar per shot.
SunnyD
Belgian Waffler
Jan 2, 2001
32,675
www.neftastic.com
shark mountable?
Ah yes, that would be it.
cheezmunky
298
shark mountable?
the truck-mounted laser was just a side note. The 747 you are speaking of is the ABL (airborne laser) from OP's article and will cost well below $1m per shot...unless they've changed that drastically since I worked on it
Modelworks
16,240
7
One thing I noticed thats really different from most lasers is they are widening the beam as it leaves the laser, most laser concentrate the beam.
I guess because they want a wider point of damage.
Still , I wonder what this thing could do if the beam was concentrated down to a pinpoint.
They mention tanks, but think about people being hit.
It would cut and cauterize the wound at the same time.
Truly a sight to behold.
jagec
24,442
I'm ready, man, check it out. I am the ultimate badass! State-of-the-badass-art! You do not want to fuck with me. Check it out. Hey, Ripley, don't worry. Me and my squad of ultimate bad-asses will protect you. Check it out. Independently targeting particle-beam phalanx. Whap! Fry half a city with this puppy! We got tactical smart missiles, phase plasma pulse rifles, RPG's... we got Sonic Electronic Ball-Breakers! We got nukes. We got knives, sharp sticks.
