so I built a new pc a few months ago, one thing that's been bothering me is that the air that comes out of the exhausts are kinda cold even while my gfx and cpu are running at 50oc what I mean by kinda is the back exhaust is always cool
however the top exhaust one side is hot air (as it should be) but the other side of the fan is cool (the cpu is directly under the fan)
case 302 antec
2 front 120mm intake fans
1 top 140mm exhaust fan
1 back 120mm exhaust fan
1 side 120mm intakefan (while ive not played
around with it by watching gpu temps it did drop my cpu load temp by 2-3oc)
side note I taped up the top 2 water cooler holes as I figured they might be pulling in air for the exhaust right next to it, didn't change anything
also the case's psu draws air in from under the case and pushes it out the back so its a separate system
no air is blown out or sucked into the grills at the back/ gpu exhaust grill
case 302 antec
