Question AIO Fan faint rattling sound at high rpm
rounakr94
15
My AIO fan has started to make a faint rattle/grinding like sound when it runs at full speed.
If I press on the hub or lower the speed to ~1500rpm it goes away.
Is this a typical case of bad bearing? The aio is practically not even 6months old. Bought it in end of may 2020.
Any solutions to this? Also lowering the fan speed gives slightly high temperature, but not much maybe a degree or two.
The AIO is a Deepcool Gammaxx L240 V2 RGB.
Feb 4, 2009
35,862
17,402
I’d just accept the one or two degrees extra heat and keep it on the lower speed.
Similar result with my Corsair H150pro.
High cools better but just a little bit better and i is far more noise.
Reactions: rounakr94
Stuka87
6,240
2,559
Are you sure the sound is coming from the fan, and not the pump? Its pretty common for some pumps to make a rattle noise.
EDIT: Missed the bit where you you purposely slow down that fan it goes away. If its making noise after only 2 months, I would be contacting Deepcool for a warranty replacement of that fan.
UsandThem
16,068
7,383
I bought a few of their fans (NDS140-1800) a few years back, and the bearings had noise right away as well. Even with cheap/generic fans, I've never experienced that before.
I was pretty unimpressed with them, and they were returned back to Amazon, and I replaced them with some Phanteks.
rounakr94
15
How is the pump/fan control software? I was tempted to buy a deepcool aio but was turned off by the software reviews
I’m not trying to poop on you choice just wondering what is accurate vs inaccurate
I control them using bios. Never used any software. And for led I used asrock's rgb software
mindless1
8,733
1,747
If it rattles at a mere 6 mos due to poor quality fan, odds are it will do the same thing again in 6 more mos, so if it doesn't use a sealed bearing design (and assuming it's a sleeve bearing) you can lube it BEFORE it gets very bad.
Ultimately I would be looking for a better quality fan, as thick as will fit, and dual ball bearing if you can tolerate a slight bearing noise in exchange for much longer life, though major brand sleeve bearing fans have reasonable life these days too, certainly far more than 6 mos.
VirtualLarry
56,578
10,215
I've been using this CoolerMaster MasterLiquid Lite 240 240mm AIO LC kit, for probably over a year now, maybe nearly two or maybe more? Been a while since I installed it. At least a year and a half. Anyways, using stock CoolerMaster fans that came with the kit, horizontally-mounted, no real noise that I can hear. (The pump did make some noise, earlier-on, but it seemed like it righted itself, eventually.)
