Aida32 vs Sandra?
dbwillis
Banned
Mar 19, 2001
2,307
XMS3200LL @ 2-2-2-6-1T / 2.6v
2.4B @ 172fsb / 1.575v
Asus P4G8X -Deluxe
With Aida32 v 3.20:>
-----write - 1157
-----read - 0 ---WTF?
With Aida32 v3.40:>
---write - 1157
---read - 4336
Tetsuo
10,908
13
Corsair XMS2700 2x256mb @ 2.5v
Iwill P4HT
mhz = 2533
fsb = 115
mem = 296
cas = 2336 1T >
read = 2246 >
write = 813 :)[/quote]
sucky results....
OverVolt
14,278
89
Giga-Byte AMD761
Sammy 2x 256 Cas2 stock volt 140mhz (280DDR)
Read 1647 (don't laugh plz)
Write 567 (again ^)
DAPUNISHER
32,293
33,119
P4PE/L
Apacer 3200DDR CL3 1-512mb stick@DDR418 2.5-3-3-6@2.6v
167fsb
CPU-3.006ghz (Increase in ambient temp forced reduction in overclock, imagine that :p )
read-3050
write-1095
DAPUNISHER
32,293
33,119
Soltek SL-75FRN-L Nforce2
Apacer 3200DDR CL3-3-3-7 2x512mb@DDR422@2.5v
FSB-211mhz
CPU-2.33ghz
read-3167
write-1254
:Q
SupermanCK
2,264
Originally posted by: poMONKey
Originally posted by: MrMajestyk
Apologies, yep 2.6/2.7/2.9.
Wondered how he gets 2.5v ? Is it a voltage mod ?
isnt 2.5v default? you wouldnt see it...
YALL are so funny...it just a mistake on my part from copying and pasting thugs format and forgot to change the 2.5v...so it should be 2.6v...my bad...LOL
Tetsuo
10,908
13
Originally posted by: tetuyeda
Corsair XMS2700 2x256mb @ 2.5v Iwill P4HT mhz = 2533 fsb = 115 mem = 296 cas = 2336 1T > read = 2246 > write = 813 :)
sucky results....[/quote]
bleh....
mhz=2600
mem=302
cas =2225
read = 2375 >
write = 782
Paveslave
180
I don't know if I ran the test right, I just clicked on memory read/write and it gave me some numbers.
Mem Read: 3497 mb/s
Mem Write: 809 mb/s
Tetsuo
10,908
13
Originally posted by: tetuyeda Corsair XMS2700 2x256mb @ 2.5v Iwill P4HT mhz = 2533 fsb = 115 mem = 296 cas = 2336 1T > read = 2246 > write = 813 :)
sucky results....
bleh.... mhz=2600 mem=302 cas =2225 read = 2375 > write = 782[/quote]
different processor now...
mhz=2110
mem=328
cas =2226
read = 2581 >
write = 795
shoman94
458
Corsair Twin XMS3500c2pt 2x512mb @ 2.5v
AOpen AX4C-Max (Canterwood) (dcddr)
mhz = 2566
fsb = 150
mem = 375mhz dcddr
cas = 2226
> read = 3678
> write = 1753
Changed things a bit........
mhz = 2740
fsb = 161
mem = 322mhz dcddr
cas = 2225
> read = 3977
> write = 1543
Changed a bit more... ;)
Corsair Twin XMS3500c2pt 2x512mb @ 2.525v
mhz = 2740
fsb = 161
mem = 402mhz dcddr
cas = 2.5,3,3,7
> read = 3891
> write = 1876
Yourself
2,542
2x512 mb Twinmos w/Winbond BH5 chips
Asus P4G8X-D E7205
mhz = 3293
fsb = 183
mem = 366mhz dcddr
cas = 2226 2T
> read = 4474
> write= 1161
**Edit**
Changed to 1T
> read= 4649 :Q
> write= 1161(no change)
Paveslave
180
So does this check the mobo or the RAM? I am confused about this test, can someone explain what exactly this is testing. I know it is testing Read/Write ablility of RAM, but is it limited to what the mobo can transfer or what? Should more or less RAM make a difference? How can I make the tranfer rates better? K, thanks for listening.
bedrocked
227
Corsair 2700LLPT @ 6-3-3-2 (scddr will retest when my other stick comes in with dcddr)
MSI K7N2L
mhz = 2100
fsb = 190
mem = 378
read = 2798
write = 1026
hm read seems a lil slow, due to relaxed timings?
THUGSROOK
11,847
on my system.....
"turbo" (otherwise known as 1T COMMAND) has the larger effect on read = +215mb / +3mb write
going from cas 2.5-3-3-7 to cas 2-2-2-6 has a larger effect on write = +40mb / +161mb
id say by the way the scores are showing on various platforms ~ this bench does test the entire memory subsystem.
Corsair Twin XMS3200LL 2x256mb @ 2.5v
Asus P4G8X-D e7205 (dcddr)
mhz = 3400
fsb = 179
mem = 358mhz dcddr
> BASE TEST < read / write
cas 2.5-3-3-7 2T = 4559 / 1034
> TURBO <
cas 2.5-3-3-7 1T = 4774 / 1037 (+215mb / +3mb)
> CAS2 <
cas 2-2-2-6 2T = 4599 / 1195 (+40mb / +161mb)
> BOTH <
cas 2-2-2-6 1T = 4804 / 1197 (+245mb / +163mb)
Elcs
6,278
Running TURBO memory settings on XP 1800+ on EPoX 8KHA+ with Crucial PC2100 DDR
(dunno what every little number is :D)
Everything else running stock.
Read - 1909 MB/s
Write - 611 MB/s
Blooz1
621
I was foolin' with this a little last night as I tried some different settings.
I also noticed a difference in results when I went from 2-2-2-5 at 11x200FSB to 2.5-3-3-6 at 11x205FSB. Both scores dropped, even though the clock speed was higher. I tried a couple of other settings with similar results.
I agree with Thugsrook that it does test the entire memory sub-system, and it seems that clock speed is not a great factor from what I've seen in my tests. That seem like a good thing to me for a memory bench.
Jgtdragon
3,816
19
This test appears to test more on your chipset then the actual memory sticks. Most of the dual channel performed better than signle channel chipset. My crappy Samsungs are hanging in there with the corairs?
Tetsuo
10,908
13
Also, the higher your FSB, the higher your mem. scores. At least from what I've noticed
