Ahh, simple probability problem I can't get
Syringer
19,333
Jilll's average bowling score is 170 with standard deviation of 20, Jack is 160 and 15.
What's the prob that Jack's score is higher?
Syringer
19,333
Lisa: Come to Homer's BBBQ, the extra 'B' is for BYOBB.
Bart: What's that extra B for?
Homer: That's a typo.
beer
11,169
Are we assuming normal gaussians here?
You have your mean
you have your variance
convert them into standard gassians and use the CDF table for the random variables of their scores
TuxDave
10,571
Find the probability that Jack-Jill is greater than 0. You subtract the means, you add the variance, and then use a Z-table.
depends on jacks efforts in the attempt to get laid that night
if he's goin for nook, he's gonna let her win
KnickNut3
2,382
:thumbsup:
iamme
21,058
wtf are they doing bowling??? there are pails of water to be fetched!! :|
Iron Woode
31,400
12,876
Jack and Jill
went up the hill.
each with a buck and a quarter.
Jill came down with $2.50.......
Syringer
19,333
You're a geeeeeeeeniusss!
KnickNut3
2,382
Definitely. His score is NOT a random variable--it is inversely proportional to her hotness.
beer
11,169
That sounds like a conditional RV to me.
Solve for the joint PDF! They're obviously not indepedent, so you're stuck trying to solve for the marginal then...
but if you bring a joint into the picture, jack being high may alter the array of methods used in getting the nook
