AGP X1950PRO 512 & P4 Bottlenecks - Questions Answered
Paratus
17,711
15,983
How many times have we heard the following:
"I don't want to upgrade to PCIE yet so I want to know will my processor bottleneck an AGP X1950PRO"
To help out the larger number of ATVF posters who are still interested in an AGP upgrade I've taken a look at whether a decent P4 Prescott system (my main rig :) ) will bottleneck my new X1950PRO 512.
My system consists of the following:
CPU: P4 3.2E Prescott (3200Mhz 16X multi 800mhz FSB effective)
MOBO: Asus P4P800 E Deluxe (Intel 865PE chipset with PAT)
RAM: 2Gigs dual channel - 2X512MB Corsair XMS DDR 400 2-2-2-5 & 2X512MB Crucial Ballistix DDR 400 2-2-2-5
VC: Diamond Viper X1950PRO 512MB (Core 580 Mem 1400 - effectively built by Sapphire)
PSU: Enermax Liberty 500W - Dual 12V rails 22A max per rail - 32A max combined
CPU Cooler: Zalman 9500 CNPS LED
HD: Boot/App Drive WD 160Gig 7200RPM 8mb cache
LCD: Planar 19in 1280x1024 native 25ms pixel response
Since I don't know how to really benchmark a video game I stuck with using built in benchmarks to check for bottlenecks. My testing consists of the following apps:
1) 3Dmark03
2) 3Dmark05
3) 3Dmark06
4) HL2 Lost Coast Stress Test
5) F.E.A.R. in game test
Each one of these benchmarks was run at 3 different CPU speeds to tease out the point where the CPU becomes the bottleneck:
1) 2800Mhz - FSB 175mhz Ram DDR 350 2-2-2-5 (I expected to run the ram higher with a divider but my higher dividers disappear when I'm below 200Mhz :confused: So this speed will be a bit slower than a stock Prescott at 2.8 and definatley slower than a Northy at 2.8)
2)3200Mhz (stock) - FSB 200 Ram DDR 400 2-2-2-5
3)3600Mhz - FSB 225 Ram DDR 450 2.5-3-3-6 (I have not optimized this OC so more performance maybe possible)
All OCs were at stock voltage. It appears I have some headroom left as I almost manged to boot into windows at 3.8 with stock voltage
For F.E.A.R and Lost Coast I tested at the following settings:
1)1024x768 0XAA Trillinear
2)1024x768 4XAA 16X HQAF
3)1280x1024 0XAA Trillinear (960 for FEAR)
4)1280x1024 4XAA 16A HQAF (960 for FEAR)
3Dmark was tested at the default settings
Before we get into the data what we are looking for is following:
1)Large changes in FPS or Score with CPU speed changes at the same settings are indications that the GPU is waiting on the CPU and hence a CPU bottleneck
2)No change in FPS or Score when increasing the resolution and settings at the same CPU speed is also an indication of the GPU not being fully utilized and hence a CPU bottleneck
3)Small changes in FPS or Score when CPU speed changes at the same settings are indications the GPU is fully utilized and is a GPU bottleneck
4) Large drops in FPS or Score when increasing resolution and settings at the same CPU speed is an indication of a GPU bottleneck
Catalyst v7.2 was used for all testing.
Vsync was not enabled
HQAF was checked in CCC
Lost Coast - all settings at Max
FEAR - all settings at Max except no Soft Shadows
So without further ado the data:
3D Mark 03________________________________________________
CPU Speed &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp Score
2.8: &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 14302
3.2: &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 14715
3.6: &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 15113
Comments: There's not much to talk about here. Obviously a P4/X1950PRO rocks 3Dm03. We see about 400PTS for each 400MHZ increase. We're basically a bit CPU limited but for a benchmark this old and at 10x7 it was to be expected.
3D Mark 05________________________________________________
2.8: &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 6458
3.2: &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 7227
3.6: &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 7781
Comments: 3Dmark 05 is a bit more interesting. We see almost an 800 pt jump for a 400mhz increase from 2.8-3.2. From 3.2-3.6 we see another 550 pt jump. It looks like we are completely CPU bound at this point. Maybe at 4.0Ghz we would see scores similar to an AMD or low end Core2. While I didn't record it I did run at 3.6 with a core OC of 30mhz on the X1950 and got a whopping 4 extra pts.
3D Mark 06________________________________________________
CPU Speed &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp Score &nbsp &nbsp &nbsp Sm2.0 &nbsp &nbsp &nbsp Sm3.0 &nbsp &nbsp &nbsp CPU
2.8: &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 3963 &nbsp &nbsp &nbsp &nbsp 1753 &nbsp &nbsp &nbsp &nbsp 2058 &nbsp &nbsp &nbsp &nbsp 817
3.2: &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 4157 &nbsp &nbsp &nbsp &nbsp 1801 &nbsp &nbsp &nbsp &nbsp 2065 &nbsp &nbsp &nbsp &nbsp 928
3.6: &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 4328 &nbsp &nbsp &nbsp &nbsp 1845 &nbsp &nbsp &nbsp &nbsp 2081 &nbsp &nbsp &nbsp &nbsp 1038
Comments: Now with 3Dmark 06 we see a roughly 200pt jump for each 400 mhz increase in the CPU speed. This is mostly due to 06 taking your CPU into account in the total score. And in fact looking at the CPU score we see the largest jump. The 3.6 score is low but fairly close to more modern systems.
HL2 Lost Coast_____________________________________________
CPU &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 10x7 &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 10x7 &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 12x10 [/u] &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 12x10
Speed &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 0XAA-Tri &nbsp &nbsp &nbsp 4XAA-16XHQAF &nbsp &nbsp &nbsp 0XAA-Tri &nbsp &nbsp &nbsp 4XAA-16XHQAF
2.8: &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 69.75 &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 67.55 &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 69.23 &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 67.32
3.2: &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 79.28 &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 78.01 &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 80.11 &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 75.76
3.6: &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 84.37 &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 82.92 &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 85.85 &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 78.76
Comments: Ok now on to a benchmark that actually matters. It's obvious that this game engine is completely CPU bound. Each time we up the OC on the CPU we get a good boost in frame rate. Although the rate of increase is dropping as the CPU speed increases suggesting we are starting to load the GPU. This is reinforced by the fact that at 12X10 with AA an AF there is a measurable drop in FPS and the 3.2 and 3.6 FPS at these settings are closer than the lower rez FPS at the same CPU speeds.
The one thing to point out to the upgrade now crowd is even at 2.8Ghz at 12x10 with 4XAA/16XAF I averaged over 67 FPS if thats not playable I don't know what is. While it IS a CPU bottleneck I have to say who cares at those FPS.
F.E.A.R___________________________________________________
CPU &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 10x7 &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 10x7 &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 12x9 &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 12x9
2.8: &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 22/66/200 &nbsp &nbsp &nbsp &nbsp 20/53/162 &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 21/57/155 &nbsp &nbsp &nbsp &nbsp &nbsp 18/45/129
BrkDwn: &nbsp 5%/33%/62% &nbsp 11%/34%/55% &nbsp &nbsp &nbsp 7%/32%/61% &nbsp 12%/42%46%
3.2: &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 28/77/210 &nbsp &nbsp &nbsp &nbsp 25/59/167 &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 25/64/168 &nbsp &nbsp &nbsp &nbsp &nbsp 22/49/134
BrkDwn: &nbsp 0%/20%/80% &nbsp 0%/38%/62% &nbsp &nbsp &nbsp 0%/31%/69% &nbsp 5%/42%/53%
3.6: &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 30/77/203 &nbsp &nbsp &nbsp &nbsp 25/60/173 &nbsp &nbsp &nbsp &nbsp &nbsp &nbsp 26/66/180 &nbsp &nbsp &nbsp &nbsp &nbsp 22/50/135
BrkDwn: &nbsp 0%/15%/85% &nbsp 0%/36%/64% &nbsp&nbsp &nbsp 0%/26%/74% &nbsp 1%/48%/51%
Comments: FEAR is the opposite example from Source. We are mostly GPU bound here. The scores are very close across the settings at both 3.6 and 3.2. At 2.8 and at lower rez we are a little CPU bound but once you up the rez to 12x9 with AF and AA it's basically the GPU holding you back. FEAR could actually use a faster GPU
________________________________________________________________
So is the X1950PRO worth it? For me - Hell Yes!
If you have an older rig that still has decent specs (P4 800mhz FSB/HT, AXP 2.0Ghz and up, or any A64 with at least 1Gig of ram) a good PSU or are willing to get one and you fit one of the following then do yourself a favor and consider an X1950PRO:
1) Don't have the time for a complete rebuild of your rig just to game.
2) Don't have the money to buy a new mobo and/or CPU and/or RAM AND a new GPU
3) Don't want to upgrade to a cheap mobo just for PCIE.
4) Are generally satisfied with you rig except for games.
So there it is. I hope you guys find this useful! It took forever to format! :p
apoppin
34,890
alienbabeltech.com
Originally posted by: Paratus
oops! works still in progress!
nice work ... keep going ...
my 850w OCZ arrives on monday and i have the 7800gs also till tuesday
[you can bet i am trying the 7800 first with the new PS ...
then the Sapphire]
so i will also try to replicate your tests
also, for the first time i will have a *overkill* PS for my 2.80c so i may be able to push it beyond 3.31Ghz
the only think i remember was that my x1950p/512 scored closer to 8K in 3DMark05 ... but i'll retest it
and *nice work* i can copy your "chart" and just replace with my numbers :D
ElFenix
102,404
8,575
nice work. looks so far like the 2.8 is pretty bottled up (look how even the frame rate remains), with the 3.2 being less so
Paratus
17,711
15,983
Finally got the formating right.
Man we need some better table support fusetalk
postmortemIA
7,721
40
nice work, only problem is that 2.8-3.6GHz is not enough range, in other words C2D with 2.0+GHz blows away even your overclocked P4.
imported_thefonz
244
My brother has a old athlon (not 64) with a 5200 and he can't play anything at all really, I'm thinking this would be a good upgrade for him. Gunna email him this post.
Thanks paratus
apoppin
34,890
alienbabeltech.com
that isn't the point ... it's about the currently last fastest AGP upgrade for an old CPU and what CPU speeds do or not do to bottleneck it
Topic: AGP X1950PRO 512 & P4 Bottlenecks
Paratus
17,711
15,983
Exactly - Core 2 does crush my P4 Oc'd or not. The point however is that a P4 even at 2.8 is sufficently fast enough (from my limited testing) to provide good AVG frame rates in CPU bound games like Source, and the X1950 PRO can provide decent FPS in GPU bound games like FEAR.
The only real question that needs to be answered is wheather or not another cheaper card like the 7800GS can provide the same performance because the platform ends up lopping off the maximum performance of the better card.
Maybe apoppin can help us with that ;)
Paratus
17,711
15,983
Thanks paratus
No problem!
Stumps
7,125
nope, the 7800GS will still lag behind the X1950Pro on a P4...I've found in my testing of the two cards that the difference is still around 20% in a lot of games....pretty much as it is with an A64 rig...maybe a bit less, the faster A64 does let both cards stretch their legs, but past 2.6ghz...the 7800GS becomes the bottleneck, a X1950Pro does not.
Infact I believe even at 2.87ghz, my single core A64 bottlenecks my X1950Pro...I'll be able to confirm this in the next couple of weeks when I upgrade to a C2D and 775 4coredual VSTA setup.
tfcmasta97
2,003
thanks a lot for this, it gives my Xp2800 64+ agp system a light of hope for another few coming years
<3 u op!
ArchAngel777
5,223
61
It is important to note that even the games that ARE CPU Bound, the difference is quite small. A 10 - 15% increase in framerate is absolutely not worth it when you have to buy a CPU + Memory + Motherboard. If you can pop in a new CPU only, then it *might* be worth it.
So, for me, the issue isn't whether something is CPU bound, but whether the difference between a P4 3.2 Ghz Versus Core2 Duo is worth the price of the upgrade. Generally speaking, it isn't worth it at all as the P4 is only *barely* CPU limited from your tests.
Edit **
I see people trading in their X2 939 Athlon systems @ 2.5Ghz for a Core2 Duo upgrade... The problem is, the cost of that upgrade is at least $500 and the difference certainly isn't visable in games - yet - and it might not be so another year or two. I don't see why people spend so much money on the CPU when the major factor in gaming today is still the GPU. Seeing someone with a 7600GT and a Core 2 Duo @ 3.2 Ghz makes me laugh as they have it backwards for gaming (speaking of a friend I have). His X2 @ 2.5 Ghz could have went a long way with that $500 going towards a real video card.
apoppin
34,890
alienbabeltech.com
i can *already* answer that
it can't provide the same performance ;)
the 7800GS OC - even o/c'd - sits pretty evenly *between* the x850xt and the x1950p in terms of performance
in Oblivion it is no contest ... the x1950p clearly 'wins' ... in other games like FEAR it is "closer" in performance
that is part of the reason i am keeping my x1950p [the other *biggie* being financial ... i am *losing* less money this way - in view of having to upgrade my PS eventually, anyway]
if you like, i can do some additional benchs Mon evening [assuming i have time] with my x1950p and 7800GS o/c'd to the max ... and my CPU o/c'd also
but what "research" i have done supports your figures
--and the "chart" format is already done :)
:thumbsup:
i might just copy the formating, anyway
--nice job!
apoppin
34,890
alienbabeltech.com
*radical*
i must be on NewEgg's "superfast list" ... the 850w OCZ i ordered Wednesday Night is arriving today!>>>!!!!!!!!!!
so i have the whole weekend to repeat your tests .... with the 7800GS also ...
we'll see what it *can* do, also ... at it's max o/c ... and i can *then* RMA that 7800GS on Monday
:thumbsup:
if anyone is interested :)
now i'll see what my CPU can *really do* in an O/C ... 'hoping' for 3.4Ghz [over 3.31 which is stable max currently]
and that 850w OCZ "better" be quiet :p
ArchAngel777
5,223
61
*radical*
:thumbsup:
LOL, i'd laugh so hard if it sounded like a Jet Engine.
apoppin
34,890
alienbabeltech.com
*radical*
:thumbsup:
you have a *sadistic streak*
:Q
what did i do to you that you wish great evil on me?
:confused:
:D
*all* the reviews noted it's lack of noise in comparison to other high end PSes ...
that's what pushed me in the direction of OCZ ... along with the $185 after MIR price
i'll let you know ...
... anyway :(
apoppin
34,890
alienbabeltech.com
i got my 850w OCZ tonight ... *upgraded* to 4x 20a on the 12v rail :)
am about to install it and i'll check the 7800GS out first ...
then, if my pro's scores come close to yours in 3DMarkXX, i won't bother to replicate everything ;)
apoppin
34,890
alienbabeltech.com
what is your memory divider set to?
is that 1:1?
i get 7537 in 3DMark05 with a NW 2.80c at 2.8 Ghz [stock] ... you get 6458 ...
i think your FSB is way low when you underclock ... that 's very likely it ...;)
BUT ...
i get 8075 @ 3.25 Ghz ... you get 7781 @ 3.6 Ghz !
:Q
huh?!?
:confused:
using Cats 7.1 with CCC
... Abit IC7 ... 2x256 OCZ and 2x256 Mushkin PC3500[+]
Sapphire x1950p/512M ... OCZ 850w 4 rails @18a/66a total/Win2K
oh yeah ... my OCZ is *quieter* than my ThermalTake 480w which it replaced ... and i thought TT was already quiet
:cool:
:heart:
nitromullet
9,031
36
He has a Prescott...
You have a Northy...
That might explain the score differences at the respective clocks. IIRC, the Prescott was specifically designed to run well above 3GHz, and clock for clock was slower than the Northwoods below that in many tests, but generally faster clock for clock above...
I'm not sure how 3DMark tests the CPU, but you can see in some situations that the Prsecott loses badly to the Northwood at 2.8Ghz, but starts to close the gap again at 3.2GHz, and I imagine (theoretically) would pull way ahead around 4GHz.
http://anandtech.com/cpuchipsets/intel/showdoc.aspx?i=1956&p=22
There was a reason that people didn't like Prescott, and it wasn't just the heat...
edit: I looked at your post again, and the above 3GHz theory doesn't hold... Maybe his memory clocks are low, or Northwood is just really better than Prescott...
Good news for you: your fps should be better than his at the same clocks...
edit2: nice work OP. I know this took some time. Respect to anyone who does benches, posts screenies, makes how-tos etc... Your contributions are appreciated.
Stumps
7,125
is that 1:1?
BUT ...
:Q
huh?!?
:confused:
:cool:
:heart:
is that all, I get higher than that with my A64 3000+ running at stock...but wait didn't you say that an overclocked P4 could beat a stock A64 3000+? :roll:
puts on flame suit and runs like a muthafvcker...
Paratus
17,711
15,983
my dividers were 1:1 because below FSB of 200 my BIOS 'looses' the higher multipliers. So at 2.8 I was at DDR 350. At FSB 200 & above I can set my RAM to DDR 500 or 533.
I verified CPU & RAM speed with CPU Z.............
It maybe that a northy does beat the stuffing out of a Prescott. :p
I'm also using Cat 7.2.
