AGP X1950 Pro power requirements
apoppin
34,890
alienbabeltech.com
what am i planning ... all the way *past* Quad Core Barcelona with X-fired r660s
--with 4 HDs in RAID and the usual excessive *stuff* :p
what hype? ... i think 850w is sufficient but not overkill for my plan ... and my OCZ is *really quiet* ... $185 is not a lot which also gets me an *exchange* warranty service for 3 years.
--and your 500w seasonic might be OK if you are not a big OCer nor plan to upgrade to SLI
i just wanted something over 'minimum'
IF your PS does fail ... you suffer ;)
-i prefer to err on the side of caution
rise
9,116
46
never had a psu fail thankfully but i just checked the ol' kill a watt and loaded i'm pulling 360w from the wall with my printer, lcd a few usb etc.
at ~ 85% efficiency, my components are only using ~ 300w.
if r660 will need less power than r600(when it finally arrives), i just don't see you needing anywhere near 850w.
i'm not a huge oc'er but from your sig, neither are you.
