? agp slot construction, help
ilist
36
My agp card move in slot free. Can I to consolidate agp card in slot and to do better contact (there is spring-mechanism in slot).
I use savage 4 32m and I have some corrupt images in agpx2 mode.
I'm user only and understand english bad, I'm sorry.
Thanx.
fic va503+(mvp3)rev1.2a(e-o037)4204, k6-2 500(5x100), 64mb pc100,
savage4 agp 32mb (diamond s3 s540 ..c4A0F, winbond..7, 125/125),
wd 153aa udma(1ry ma), cd rom mitsumi fx810 non-udma(2ry ma),
sb vibra ct4170 isa, ps/2 mouse, psu ATX 250w.
win98se, via 4in1 4.25a(4.20 pci bridge), dx7.0a.
m/b bios je439, video bios 229... .
vid drv 8.20.29 (JGC's 2.1)
Usul
1,016
Use some cable ties to hold it down, but do NOT mess with the contacts in the socket!
Bartman39
Elite Member | For Sale/Trade
Jul 4, 2000
8,867
51
Not to sure but the 503+ did not have an AGP slot up to spec with your video card??? Might be the problem with your image distortions... I agree to try plastic cable ties to hold the card in and stable otherwise the slot maybe worn out???
ilist
36
Thanx.
2Bartman39
Yes, va503+ has spec agp 1.0, it is know prob. But I have very free movings in slot...
Can I to buy this plastic cable ties anywhere?
Can I anyhow mechanicly to perform contact in slot?
Bartman39
Jul 4, 2000
8,867
51
Sorry I cant help much more but the cable ties can be found at and electrical supply house or Radio Shack even at a general hardware store (anywhere that has electrical supplies). You will have to be inventive (figure a way to do it...) to use the cable ties. I think if you get the card held in place properly or moved to where it makes the best contact you might get lucky... Other than trying a different AGP type card in your AGP slot I dont know how to tighten up a loose slot??? Other than changing the board...
ilist
36
To tighten up a loose slot is impossibly, but in slot contact is spring-mechanism and I think how to regulate it. I need to break a agp slot 1 time :( and to know this mechanism. I can't try other card/board now.
Thanx.
