After updating from 19" 1280x1024 to 24" 1920x1200 (HP ZR24), web scrolling image update is jerky unless I scroll quite slowly. This is with both Firefox and IE. Is it because the video card has to process more pixels? Even with a Nvidia 9600GT?
Can I ask, if you sit fairly close the the monitor do you notice gamma shifting in the corners?
And I know my web behaves that way prior to driver installation. Try uninstalling and reinstalling drivers and check to see that smooth scrolling is checked. But, do it in the reverse order mentioned.
