After Effects Users: Need Help!
Coldkilla
3,944
I have After Effects 7/CS3 and nether of them have the effect I used to use...
Blur and Sharpen >> CC Radial Fast Blur
Can I ask, where did this effect go? Can I download this effect? Was it taken out? My head's about to explode... I used to use that effect quite a bit... and now its gone. :(
LikeLinus
11,518
670
The effects come on the DVD. It's a third party plugin set by Cycore FX.
Just re-install from the DVD.
LikeLinus
11,518
670
You may also want them to add Color Finesse and Keylight from the DVD also.
Both of these plugins are excellent and a great addition to your workflow.
