borderdeal
- Aug 4, 2013
- 132
- 0
- 0
I recently upgrade to a 49" 4k Monitor and a 290 cannot handle 4k at all. Even if I lower the settings. 4k is just too much. I used the dying light demo and at 4k I could not get acceptable frame rate . I lowered the resolution to 1440p and I can run it at the highest with good frame rate to have FreeSync working. The thing is that it looks better with high settings at 1440p than 4k with medium settings and it is really smooth where 4k thanks pretty bad.
I will be setting a second 290 card that I got and I am currently testing (got it from ebay for only $102 shipped because it was overheating) So I will have a crossfire setup for about $300 once u count the AIO cooling and the adapter for the card. Will see how it runs. But man 4k is brutal on the 290. I have also tested Farcry 3 and again at 4k it thanks pretty bard even if I go to medium settings. It can run fine at 1440p at ultra settings though. I lowered it to very high though because in some parts it would get less than 42 FPS and that would feel really weird when it is not in FreeSync range. It stutters for a few seconds (2-3) so I decided to lower the resolution one notch and that solved the problem. I doubt u will make a 970 work at 4k even if you lower the settings. So get a used 290 or 290x or at least a 980 and OC the pants out of it and see if that can run it (but I doubt it).
I went from a 7870 GHz edition ( I tried it and it failed hard even at 1440p) bit it ran pretty much anything at 1080p. FarCry 3 I ran at very high and it was fine. My card was factory OC to 1.1 GHz and I believe 1200 MHz on the memory. It might be another option to hold you over until next gen cards hit. A Used 7870 or 270x should be ok for 1080p
