Hi all,
I've been browsing for a few weeks while researching and contemplating my first build vs. years of buying Dells. I'm currently just about end-of-life with my Dimension 8300 for a few reasons. The only change I made was to put a LeadTek 6600GT in about 2 years ago and while I've lived with the incredible noise, I'm ready for something faster and quieter.
My main goal is a reasonably quiet machine both at idle and load with enough performance to run high-end graphics applications and provide reasonable performance on any current or soon-to-come high-end game. I also want the machine to be pretty easy to build and bring up (Vista). I may be interested in OCing or upgrading later, but only after I've got the machine up and running for a few weeks. Finally my budget is in the $1,500-$1,800 range
I would really appreciate feedback on the compatibility of the components I've come up with so far, with regard to ease-of-build, anything missing you would recommend, and/or possible problems you might forsee (i.e. length of modular PSU cables in a p180b case). So without further ado...
Case: Antec P180b - Gets good reviews for noise suppression and overall quality. Only concern is how hard it will be to achieve a decent build.
Mobo: ASUS P5B-E - Seems to have everything I want and nothing I don't.
Proc: e6600 (what else!)
Ram: Corsair XMS2 2x1GB kit DDR2 800 - I'm not sure if I can get something less expensive that's just as good.
PSU: Corsair HX520w - I wanted modular, thinking it will make for an easier build, and I wanted quiet and cool. Corsair over comparible Seasonic based on reviews. Concern is the bottom air draw in a bottom position on the case. Will this restrict airflow in?
HDs: 2 x WD Caviar SE16 WD3200KS - Wasn't sure WD vs. Seagate but this seems to get the best reviews for quiet. Still considering Raid 0 vs. Raid 1 vs. adding a third drive for best of both.
VC: XFX GeForce 7950GT - This was the hardest choice. Compared to the similarly priced PNY version, I am willing to take the risk on the fanless card to get the quietest build as long as I can control the heat in the case. As a backup, would it make sense to throw a Zalman VF900 onto this card? Is there a better card for this if that's the plan? Definitely want feedback here.
DVD: Sony AW-Q170A-B2 - expensive, but I wanted fast loading, quiet, and dependable. Don't care much about lightscribe. Any other choices?
Sound: CL Audigy 2 ZS SB0350 - too many problems with the X-Fi so far. This was the conservative play.
This comes to just about $1,600 on newegg. Wish List: https://secure.newegg.com/NewVersion/WishList/MySavedWishDetail.asp?ID=3696391
Thanks to all for reading this far and for any feedback.
-Dan
-Dan
