matrix5646
Alright. Just need some advice from you guys. Its time to upgrade the old AMD 1800+ system. Did great for 3 years..time to retire it and jump up a notch.
What I'd like to get is a
AMD Athlon 64 3000+ Processor Socket 939, with a good PCI express based motherboard. I was going to get the DFI Ultra but it needs a 24 PIN based powersupply. And according to their website it may not be stable if i simply buy the 10 dollar converter. And the last thing i want is an unstable pc. Now i've looked around and I can't seem to find a PCI Express 939 board that works with a 20 PIN PSU?? Trying to avoid purchasing another powersupply if possible. the system will be
running 2 - 3 HDs (mix of ide and sata for now)
one dvd rw
an audigy 2 snd card
and at MOST a 6800GT or X800 XL (havn't decided on this yet)
if anyone could give their reccomendations..or reccomend a website that could help me out. I would really appreciate it. Thanks,
one dvd rw
