Hi there,
My CPU is a Celeron 466 o/c 582 using 2.05V core voltage. The room temperature here is a constant 30+ degree C, perhaps a drop of 1-2 degree at night. According to the onboard sensor, my CPU temp is around 36-38C when idle, 42-44C on full load. The system temp is around 37-40C. Is this within normal range?
Besides the power supply exhaust fan, there's a 80cm exhaust fan right beneath it. I was considering adding another casing fan....should I go for a 80cm intake fan which can be placed at the bottom of the front panel, or go for a 80mm slot exhaust fan?? Which is more efficient?
Any feedback will be greatly appreciated!! 🙂
Jeff
Jeff
