flexy
hi !
i plan to buy the following...if anyone has any input/recommendations on the config...let me know 😉
() Athlon TBird 1.4, NO XP....there is no point in getting an XP (imho)....and 'til there is nothing better than 1.4 Ghz i'll stick with a plain TBird 1.4
() MoBo KT266A chipset (not sure about the brand yet...not too many reviews out. I havent seen anyone mentioning KT266A boards with AGP pro for example. I do not need Raid, IR and unnecessary stuff on my board, but i'd like to have as many bios-features as possible, jumperless would be best.
Btw. where is ATA133 ???? They all have ATA 100...but it's ok 😉
() Inwin S500AU.300F case with sparkle 300W PSU. Hope it's enough for my TBird...
() Cardexpert Golden Sample GF 3, i think i get the best value with this one. I dont see the point in getting a Geforce Titanium 500 (too expensive etc...) and the golden sample seems quite overclockable....
() Maxtor D740X 40 Gig.
I first wanted a IBM, but after hearing of many problems with IBM deskstars i think i better go with a Maxtor !!!
() Audigy OEM soundcard
() Samsung 950p 19" monitor
() 256 Crucial Ram
I will probably not OC my system much (maybe not at all)...so i decided that i do NOT need the following:
Cas2 Ram or 2400 DDR ram.....i dont need it....would be wasted money as long as there are no newer CPUs around with higher FSB....
PSU/CASE with more than 300W....according to newegg and others 300W should be enough for a 1.4 TBird
greetings
