Advice - display breaks down as card heats up
Axon
2,541
Yeah, this is a new case, but it sucks. There is only one fan mount that I can see and I'm not about to make another one. What would be an OMG TEH L337N355 CASE!!!11!11oneshift!!1!1!!?
kylebisme
9,396
you should have a hole for a fan on the botom front of your case. without a fan there you have nothing putting cool air in your case, put a fan there to blow cool air in and your problems will be solved.
Pete
4,953
If you want a nice, airy case, take a look at the Antec SLK3700. Dual 120mm fan mounts means a nice amount of air with minimal whine (a larger fan doesn't need to spin as fast as a smaller fan to push the same amount of air). The case is useful in other ways, and it's not too expensive. It includes a decent power supply, too.
You sure there's no fan mount near the front of your case?
Jan 31, 2002
40,819
I concur. I don't think I've seen a regular ATX case that lacks a front fanmount yet. Check again, it might be hidden. And if it truly does lack one, then make one. Duct tape is your friend.
- M4H
