Adjusting/calibrating power supply
awolkoff
249
Is it necessary to adjust/calibrate a new power supply to insure it is putting out proper voltage (e.g. 5 volts true, 12 volts true)?
If so, can I do this before hooking up the PS to everything else? Or is it necessary to run the PS under a load for a time before "dialing it in?"
as always, TIA
ASW
Jeff7181
18,368
11
I can see it now "Computer geek dies trying to stabalize Athlon XP2500 at 2.5 Ghz"
