After nine years I decided to build a new gaming PC. If needed I will post all the components but the short of it is, my existing PSU is a 750W modular Zalman that I would like to keep since it is more than adequate for my new rig (which depending on whose calculator you use will consume about 600W on average.
My GFX card is the XFX RX 7500 which consumes about 180 peak gaming watts (depending on the game), again, depending on who you read. The card has a 6 and 8 pin connector. Problem is, the Zalman has two independent 6-pin connectors but no 8-pin connector. My thinking is, if I can use both 6-pin connectors, I will realize 225 watts (75+75+75). I have read many pros/cons regarding adapters so my question is, has anyone had success using an adapter to connect a 6-pin PSU cable to an 8-pin GFX card?
Thanks, Monk
Thanks, Monk
