Well, I got mine yesterday and installed them...
My thoughts...
the bad:
1) I had the same problems with the power plug. It's simply backwards... it didn't take long to fix, but it's still disappointing.
2) The heatspreader install for the rear RAM is ridiculous... There needs to be a better way to mount the spreader than the included sticky pads. These seem to stick to your fingers better then anything else. The weird thing about it is that the NV5 Silencer doesn't obstruct the standard mounting holes for the spreader, they could have just included mounting screws or the barbs Ackmed has mentioned. This part gets a 0/5...
I actually didn't end up using the spreader at all, but kept the KO backplate and installed the NV5 on the top.
http://www.mindspring.com/~megatron/Picture%20004.jpg
http://www.mindspring.com/~megatron/Picture%20006.jpg
I'm not sure how you guys with stock GTXes are going to install the cooling for the rear RAM, but this worked pretty well for me.
3) To clarify, the SIL SATA RAID plugs are blocked. I had to use the NV SATA plugs. This isn't a shortcoming of the NV5 itself, but I figured I'd mention it. The red SATA ports are completely un-usable. A big "thank you" to all the people who were so sure that it wouldn't be a problem.
4) I would have preferred that they didn't include the TIM, I just had to scrape it off. I used AS2 instead.
5) They changed the shape of the sink...
It is now flat:
http://www.arctic-cooling.com/pics/nv5_r2_06l.jpg
On the Rev. 1 Silencer I had for my 6800GT, the parts that touched the RAM were raised to make closer contact with the RAM. The nice thing about this is that you could use thermal paste instead of the thick pads, which are better IMO. You have to use the pads with the Rev. 3 or the sink won't make contact with the RAM.
...anyway, on to the good:
KO stock
idle:
GPU1 50C
GPu2 51C
load
GPU1 79C
GPu2 83C
NV5 Silencer
idle:
GPU1 45C
GPu2 43C
load
GPU1 69C
GPu2 64C
I think these speak for themselves... These coolers rock. Once you get them installed properly, which is a pain, you will be pleased with the performance.
