I just upgraded my AMD 64 3500 with stock heatsink/fan to a new AMD X2 4600 with AC Freezer 64 Pro.
With the old 3500 my idle temps were:
CPU: 50
System: 50
GPU: 60
With the new 4600 my idle temps are:
CPU: 58 (!)
System: 46
GPU: 53
Granted, I'm in Alabama and it's hot as hell here, but a 8 degree JUMP in CPU idle temp is a bit alarming. If anything I was expecting a 8 degree decrease.
The install of the Freezer Pro went fine. I took out my PSU and graphics card so I could easily remove the 3500. Popped in the new CPU and latched on the Freezer. I plugged it in to the CPU fan port on my mobo, put everything back in closed up the case.
My case features two intake fans, a side intake fan and a rear exhaust fan. The Freezer is positioned to blow air to the back of the case which is sucked out by the rear exhaust fan.
I've monitored these temps in NV Monitor. I haven't tried gaming or running any benchmarks because I'm afraid I'll fry my new CPU!
Does anyone have any advice on how to get these temps down?
CPU: 50
System: 50
GPU: 60
CPU: 58 (!)
System: 46
GPU: 53
