- Jan 10, 2008
- 2,873
- 0
- 0
And could definitely use some guiding advice. Been spending the past few days just looking at parts non stop for a while and now I'm really confused on what I want to get!
What I think I need:
1. Pump: Not really sure what's considered good here, people seem to like Swiftech's pumps quite a bit though
2. Reservoir: Again, not really sure what's good at all in this section. I read that the more water in your system the better performance you'll see due to the volume of liquid being a more stable rise and drop in temperature (harder for the components to heat more liquid), would that justify getting a really big reservoir?
3. Tubing: Have heard nothing but good things about Primochill's Advanced LRT, so most likely going to be grabbing that. Do I go for red tubing or clear tubing with red dyes/coolant!?
4. Fittings: Seems barbs are more reliable, however I do really like how compression fittings look though they are more expensive. I've read some issues with leaking but as long as tubing dimensions are considered, shouldn't be a problem it seems?
5. Waterblocks: Strongly considering the Koolance and XSPC blocks for the R9 290 once I can get my hands on one at MSRP. Not really sure what's good for the CPU block, the XSPC products seem like a fun blend of good performance and shiny LEDs as I plan on being able to showcase my case to people (trying to get into basic modding, no huge themed systems but basics like sleeving and such so want a nice looking case to show off).
6. Radiators: While I've seen a few popular models/lines for the other parts, I don't really see that being true here, I plan on getting a decent thickness 360 rad to mount the front of my Air 540 but I'm not sure that'll be enough to cool an OC'd 4770K and R9 290, thoughts?
7. Fans: While I have quite a random assortment of case fans lying around, I believe that cooling radiators requires a slightly different airflow design as you want to focus the air path through the rads whereas many fans will just diffuse in a large conal fashion. Was thinking of getting some Noctua NF-F12s for their popularity and quiet operation but it's a bit expensive since you can buy 3-4 cheap Cooler Master fans for the price of 1 and I may break a fan or two trying to paint them!
From the reading I've done, I don't really need to worry about CPU before GPU or vice versa much as it'll make little difference in cooling performance for both of them, just so long as I put the reservoir before the pump every else doesn't really matter.
Mainly looking for parts recommendations and such, general tips and tricks would be very helpful as well!
