Originally posted by: SolMiester
Dont forget though if you get an ATI card to budget for a decent after market cooler...
Wow, that is amazing! Did it came out of your personal experience? I assume you had a couple of ATI cards and you needed an aftermarket cooler for them, isn't it?
The stock cooler is enough, even if you don't mess with the fan. It will run hot, but it will run! If you increase the fan speed, then temperatures will drop like a brick. Where did you got this idea ? Do you think that the GTX 260 is a very cold card or what?
Yes, I have had ATI cards and friends have the 4xxx series. Dont get all heat up because I and many others happen to believe while ATI GPU's of late are great, their cooling solutions sucks....
If you think a GPU running @ 100c at load is fine, good for you. I happen to think the cooler the GPU the better.....
The GTX's extra memory will help you at that resolution over the 4870.Originally posted by: mazeroth
I can get an MSI GTX260 for $187 shipped on ebay with the 30% cash back. The 4870 costs $198, only an $11 difference. I play on a 24" Soyo at 1920x1200 resolution and have an E4300 that runs at 3.3 ghz.
The GTX260 runs Physx very well even as a dedicated GPU. Plus you gain many of the other benefits of CUDA, such as folding@home, Photoshop plugins, video encoding support, etc.If you were in my shoes, which would you go with? Another plus, I guess, is I could use the GTX260 down the road for a Physx processor when I get a new video card.
you think 280GTX or 8800GTX runs cool?
:laugh:
since 2900xt, all of AMD's GPUs run 'hot' also and survive just as nicely as Nvidia GPUs
maybe better
:laugh:
maybe better
I'm not sure, I believe the 88 does. dont forget the x19xx series was hot too. I'm just saying NV tend to have better cooling .....christ, anyone would think I was insulting the pope around here as if ATI can do no wrong since the 48xx series....LOL
X2 is a hot beastOriginally posted by: Zebo
x2 is a lot harder to cool than GX2.
http://www.xbitlabs.com/articl...crossfire_6.html#sect0
One thing that's amazing is at idle and 2D the x2 uses almost same power as 4870 by itself - I bet one core shuts down unlike the GX2s
Try water cooling... I'm a silence freak so I couldn't abide that scene. Only issue, and it's a pretty big one, is exchanging parts - such a pain with hose clamps and draining/refilling system for those of us that swap stuff all the time.
Originally posted by: sourthings
Just look at performance reviews. Right now in that segment the 4870 1GB is the superior card, it's about 3-5% less than a GTX 280 for $100 less. Probably the best bet, but on a strict comparison to the GTX 260 or 260 216, it's the better card.
maybe better
maybe better
My Asus HD 3850 never goes above 65C overclocked to 820/2150 on the stock cooler and that's at 1.275v.
