Hey folks, after lurking on this message board for a few months i decieded to set up a new system myself and now im having a coupla minor issues i could use a hand on. The main problem i am having now is gettin my TH7II mobo to recognize that the processor is a northwood, when i get to my bios (which i have flashed with 38 and the new 4w bin files.. using 4w beta drivers now) it tells me that my cpu has been changed and i need to enter cmos setup (cant remember if thats word for word what it tells me =P) or i can hit the f1 key and continue. When i hit f1 i can go on into windows xp pro(which i have installed on my new HDD) and everything runs fine (system control panel tells me im runnin a p4 at 1.79 and 512 rdram, which is good i think). One more slight problem im having is that my system doctor tells me that my Vcore is runnin about 1.47 instead of 1.55 that should be the default, i know i can adjust that in my bios but was curious if there was a problem there with the motherboard or if it was just in need of a slight bios adjustment ?
What exactly do i need to do to get mobo to recognize my cpu as a 1.80a if i have flashed with the most recent 4w bin? (tried setting my cmos jumper after i power down to clear it but that just didnt work the way i wanted to either)
Anyway, i thank you all for your time and i could really use a hand here from someone with a handle on my problems (i read a post about flashing the bios on the abit th7II-raid with a northy 1.8a, it helped alot also =P)
Bane
Bane
