I seem to be having a compatibility problem with my VIA chipset and the Aureal vortex boards. when audio attempts to be played, my system will cut out after a few minutes, and not play at all afterwards. Occasionally, I will get lock ups. I know it is a compatibility issue as I installed my old Soundblaster 16 card and everthing works fine. But I really want my MX300 tom work. I have read that others are having the same problem, but no one has posted a fix. Curious if there is a Bios Update, or driver I can install. Thanks
