Just purchased a Althon X2 4200+, KN9 SLI, and 2x512MB 4-5-4-15 2.1V OCZ DDR2-800 RAM from newegg, but the ram is really flaky -- one stick boots in slot 2 or 4, but the system doesn't turn on, and doesn't beep if it is in slot 1 or 3. The other stick just beeps as if no memory when in any slot, and I can't get the system on with both sticks in at all either.
I'm guessing it's the RAM's fault since people seem to be having trouble with OCZ in other Socket AM2 boards from Asus and Abit both. One thing I noticed was that the "auto" settings would put the voltage at 1.8v instead of 2.1V, but even manually putting the voltage to 2.1v did not help get the system to boot with both sticks at once. I assume this is a problem with the SPD on the OCZ ram, and not a problem with the Abit KN9 SLI board.
Does anybody recommend a particular type of RAM to use instead when I send this back?
I'm leaning towards the Crucial 4-4-4-12 for $160 - http://www.newegg.com/Product/Product.asp?Item=N82E16820146566
There is also Corsair 4-4-4-12 for $154 - http://www.newegg.com/Product/Product.asp?Item=N82E16820145040
Kingston 4-4-4-12 for $166 or $178 - http://www.newegg.com/Product/Product.asp?Item=N82E16820134064 / http://www.newegg.com/Product/Product.asp?Item=N82E16820134124
Finally, there is Mushkin 4-4-3-10 for $170 - http://www.newegg.com/Product/Product.asp?Item=N82E16820146106
