Abit IT7 sound problem
tsowen
115
Does any Abit IT7 owner successfully install the Realtek sound driver? I can never make the sound work. After I install the ALC650 driver on win2k, the sound manager icon shows up on taskbar. But when I click on it, sound manager doesn't show up. When I click on volume control, I get an error msg saying no sound device is found. Any idea on what the problem is? Thanks.
Steve
tsowen
115
Yes. I did. I set the AC97 Audio in BIOS to AUTO as well. Is there any jumper/BIOS that I should set? Thanks.
Steve
RamIt
777
186
Sorry I have the BD7II with XP and did not have your problem. Have you tried the manual?
tsowen
115
Yes. I read through manual. I even went to Abit's web site. But I can't find any useful info. Send email to tech support and get no response. Is there any way to determin if it's a hardware problem, or software problem? Thanks.
Steve
RamIt
777
186
Can you check in the device manager and see if you have any yellow question marks?
tsowen
115
There is no yellow question mark in the device manager. No matter I enable or disable AC97 in BIOS, there is no change in device manager.
Steve
tsowen
115
I guess I got a defective board. There is no AC97 audio in my device manager. Thanks for your help.
Steve
tsowen
115
Found the problem. The PCI bus frequency has to be 33MHz. Otherwise it won't work!
Steve
