Well okay, not literally, but it may as well be.
I upgraded my video card from the old TNT2 M64 to a brand spanking new GF-II GTS 32meg. Everything seems to work perfectly until I actually try to utilise the 3d Acceleration part.
As an example, I booted up Giants: Citizen Kabuto, and bumped all the settings up to maximum. After all, it should support it now, no?
Everything worked fine for about 10 minutes, whereapon I'm assuming the card overheated and shut itself down. I had to wait a few minutes before the card cooled down enough to even let my poor PC boot up.
Unfortunately, now exactly the same thing is happening as I sit _here_ online. The Geforce is an advanced kind of card, I don't think it should have trouble rendering an IE5 screen, honestly.
So obviously my question is what's the deal, here? I'm running a PIII 800, so it isn't like the poor card is running faster than the CPU.. My powersupply seems fine, etc.
Could it be my motherboard? Unfortunately, motherboards are my blind spot knowledge-wise. I'm using a.. -looks up the manual-.. Octek Rhino VAP133-ACP, whatever the hell that is. Could this be the problem? www.octek.com looks like it's in Dutch, so that wasn't much help.
