Originally posted by: mset
..... really!!??
You mean I can keep my current machine for email/surfing and make my new machine dedicated for my work only and run both of them at the same time from the same keyboard mouse and drive the same two monitors?
Yes, you can. This is exactly the configuration of my three systems: all three are controlled by one set of kbd/mouse/dual LCD. You'd better think about this possibility before you go ahead.
To make your work less pain, I will explain details. Kbd/mouse are connected to KVM via either USB or PS/2. In my experience PS/2 is much trouble free than USB. At least my USB KVM does not work in BIOS Setup of MSI board. So if you search for KVM with connection to 2 pcs and 2 moniotors and with PS/2 (search
here), only two models will be hitted,
here. (I am pretty sure that these are the only models available in the consumer-level market.) As you can see from the specs, LKV-DM02SK accepts analog signal only and LDV-DM02ESK accepts digital signal only. There are several possible combinations. But one thing clear is that you can't mix digital and analog. So the possiblity of using both VGA connector and DVI connector on MSI board is excluded.
KVM switch can be used for ten years or more. So the
digital KVM LDV-DM02ESK may be better for future proof, though you can't use it until you buy digital LCDs. Then you buy a nVIDIA PCI-e video card with a DVI out (GeForce 6200 TC, $50) and use DVI onboard, or buy a video card with dual DVI outs (XFX GeForce 6600 GDDR2, $120) for better image quality. If your old pc does not have a DVI-out, you also need to buy a AGP video card with a DVI-out (GeForce FX5200 or Radeon 9200, $40) for single monitor or a AGP card with dual DVI outs (GeForce 6600, $120) for dual monitor.
If you go for the
analog KVM LKV-DM02SK ($80 cheaper than the digital model), then the situation is simpler. You can buy any nVIDIA PCI-e video card (e.g. GeForce 6200 TC, $50) as you can use VGA port onboard, or you can buy a PCI-e video card with dual DVI outs (XFX GeForce 6600 GDDR2, $120) if it makes a sense for you. Your old pc has a VGA connector, so you don't need to buy a AGP card if single monitor is enough. Or you can buy an AGP card with dual heads (GeForce FX5200 or Radeon 9200, $40) for dual monitor. Morever a LCD with analog port only is about $50 less than a LCD with both analog and digital. In total, analog solution will save a few hundred dollars. But three years later, these analog devices will be mostly obsolete. But at the same time DVI devices pricier today will be at the same prices as today's analog devices.
I feel that analog solution is better at this time. Your total cost will be 2 x $200 (analog 17" LCD), 1 x $50 (PCI-e GF6200 TC card with dual heads), 1 x $40 (AGP GF FX5200 card with dual heads), $95 (analog KVM) = $585. Or buy digital LCDs (2 x $250) and a PCI-E card with dual DVI heads ($120) instead for mild future proof (total $755).
Switching Audio too? Some KVM models (Belkin Omniview, Iogear) come also with audio switch. IMO this is a really bad idea. You can't hear any sound from the PC not in use, that may be a critical warning sound! You'd better use an audio mixer like
Rolls MX42, or buy a cheap speaker.
Selecting LCDs. You should choose LCDs with
black color and
thin frame. This is not because it is stylish but your eyes will be less distracted by the center frame.
You can use a
router to not only connect two PCs but also share Internet connection. Again Gigabit router (like
D-Link DGL-4100) is recommended for future proof. (I am using this model.) Just connect two (or more) PCs to LAN ports of the router and connect an ADSL/cable modem to the WAN port of the router, and you are done.
BTW a DVI out on a video card is called DVI-A; it automatically senses the connected device and sends analog or digital signal according to the device. DVI on MSI board is not DVI-A (lacks RAMDAC).
