Regulator07
i have been running my rig with the neopower 480 for about 3 weeks now and just recently been having some problems. i definitely think it is psu related as increasing voltage to the cpu does help but should not be required. even at stock speeds (2.2 3500+ winnie) i can pass superpi 1m once and then it fails right away anytime after that, also prime goes for about 5 min then done. then also, i was running fine at 2310 (210x11) primed for 3 hours and fine, now same thing cant prime, also when i shut the computer off for awhile then reboot it runs better, when the psu is running for awhile it seems to crap out, i dont get it but i think it might be that dual rail $hit and am thinking about rma'ing it for the powerstream 520. what do you guys think any suggestions and do you think i shoud ge the powerstream 520? thanks!
