Here is the system I just bought... (with some parts from my old PC)
ASUS A8N-SLI Deluxe Motherboard
AMD Athlon64 3500
BFG Geforce 6800GT OC (PCI-E)
WD 74GB Raptor HD
1GB RAM (Corsair XMS PC2700)
The system is 100% stable and runs pretty good, but I'm only getting between 4500 and 4800 with 3dMark05. Those scores seem a bit low for my setup and I'm guessing it's because of my RAM.
I've tried changing the one DRAM setting in the memory (it's at the top of the page, I forget the name) and I changed it from "Auto" to "DDR400" but it didn't seem to make any difference... (in fact, I got a LOWER 3dMark05 score). So... I'm wondering if I could overclock my RAM to run at DDR400 since I'm running XMS series (which I was told is very good). I'm also wondering if I should manually set the DRAM timings in case the motherboard isn't detecting the 2-2-2 properly.
So, my overall question is this: How can I tweak the settings of my A8N-SLI motherboard?
Thanks for any advice.
AMD Athlon64 3500
WD 74GB Raptor HD
