http://imageshack.us/scaled/landing/132/gpu.png
http://img12.imageshack.us/img12/7540/cpuhi.png
Nah ... it must be CPU after all.
I runned HWiNFOx64 program or something.
Those two pictures are from usage when I record on 1280x720 23fps
And we can clearly see, that Max CPU ussage was 100%
And max GPU usage was 58% and 33%
Now to make sure that's rly it, I tried to record in 1920x1080 at 30fps
Resault:
CPU 100%
GPU 84% & 34%
So I guess the CPU is the one who make me lagging.
And if I understand it right, with just better CPU I would record on 1920x1080 at 25fps with no problem, because GPU won't go over 85% usage so I think it shouldn't lagg because of my graphic card after all 🙂
Anyone think I'm wong ?
Playing and recording with fraps on Dual Core= CPU limited 😉
I think you are CPU limited. The question is how much faster the AMD 5600 is going to be since the game only uses two cores. The extra cores might help when you are running the recording program though. I am not saying the 5600 will not do the job, but I think you have to evaluate the CPU based on more than just the number of cores. Total performance is what matters. The safest choice would be an i5, then you would be sure of getting optimal CPU performance. Since you say that is too expensive, you will have to choose between the 5600, an FX which you say is not available, and a hyperthreaded i3. Since you use is sort of unique, you will just have to pick one and take your chances. For gaming alone, I would say the i3 is at least the equal of the 5600, especially in a game that only uses 2 threads, but for recording while gaming, the extra cores of the 5600 might pull it ahead.
Get the i3 3220. You gain:
Same multithreaded performance as 5600k.
+50% single threaded performance (great gains in games).
Not worrying about if the games you play are playing well on AMD. MMO's in particular are playing terribly on AMD cpu's (WoW, Guild Wars 2, as the last examples).
And a lot lower power consumption.
I would stick with the A8 and overclock to 4ghz. It will match or beat an i3. This is a quad core CPU, not a dual core with HT. My 6850 does not bottleneck one bit by the A8 and I am confident that even a newer GPU wouldn't either.
If you don't have the money to swing for the i5, then I definitely recommend the A8-5600k. I can honestly say I can sell my Intel system and just keep the A8 for gaming since its perfectly sufficient for what I do.
I also think that A8 5600K can't be that bad.
It can't compare to i5, but handeling same bench like i3 cores shouldn't be such a problem for it.
And may I ask what rating does that CPU get at Windows 7 Index Experience or something (in System, to rate your PC) ?
But the processor is locked, and I don't even play those new games that you mentioned.
Playing KalOnline sometimes and Crossfire. + recording the gameplay.
And I think that i3 wouldn't be as good for that as A8 5600K
Why? because i3 have 2 cores and in this case aplication + recording program would work on the same 2 cores. That would cause laggs in my gameplay + video that is recording.
Both are 2 cores/4 threads. AMD markets a module as two cores, but in reality both of them are not really 4 cores. I wouldn't count so much on overclocking on stock solutions since my last stock cooler from AMD sounded like an airplane taking off.
Since you play those specific games, save yourself some time and go search for benchmarks in those games.
Its 4 cores and 4 threads. Don't let anyone spin it off to something different. The cores share resources to a module so technically its 2m/4c/4t. Its better than hyperthreading and has better multithreading capabilities.
http://www.anandtech.com/bench/Product/676?vs=677
As shown in this comparison, the i3 surprisingly is better even in multithreaded tests, and absolutely destroys the AMD in games.
So, add the lower power consumption and there are absolutely zero reasons to prefer AMD
The i3 is surprisingly good... but, I don't agree with the 'absolutely zero reasons to prefer AMD'. The AMD chip is pulling 60FPS+ in every game but one in those benches. The AMD quad is also cheaper, at least on Newegg (I did not scour the internet to look at prices, just went to Newegg). The AMD chip is just a few adjustments of the multiplier away from pulling ahead in many benches, too.
I don't think the OP will go wrong with either choice, but I still think the AMD chip is actually the better option, unless the extra power consumption is a factor.
I am sure you have tested it to back up your claim as well. 🙄
