A7V133 PCI divider problem
Davegod75
I've been trying to get my mobo past 140FSB forever now. I added some hefty cooling to my ICS chip and northbridge and was able to boot into windows @ 148FSB and load up sandra to check some stuff out.
It said my PCI divider was 1/3 and that the PCI bus was running at 49Mhz.
This is mostly likely my problem with stability because isn't that way too high.
Also isn't this mobo supposed to have a 1/4 PCI divider?
Is there something special i have to do to enable it?
Thanks
ok i guess that's not my problem. My mobo just doesn't like high FSB's....lets see if it likes the 1.33 AYHAJA tbird i ordered for it.
<< Sandra is wrong. The fsb is set automatically to 1/4 when the fsb is 133 or over. >>
Actually its 121 or higher for the A7V133.
