- Apr 14, 2005
- 362
- 0
- 71
My A7N8X-E-Dx with a Barton 2800 has always shown a higher CPU temp (50+*C) than my A7N8X-Dx with the same CPU. I switched to watercooling but the temp difference between the two mobo's stayed the same. I noticed when I use a Antec P160 sensor on the CPU waterblock the temp reads 39*C, but using ASUS probe or MBM5 it reads 52*C.
Has anyone else experienced high CPU temp readings on a A7N8X-E-Dx mobo; or know of any documented problems with the CPU temp sensor ??
