Insert_Nickname
- May 6, 2012
- 4,971
- 1,692
- 136
Yes that CX430 would run, with help of that connector, an R9 270X, but say a year down the road when say 290x's and low end i7's are cheaper, I'd be a bit sceptical of using a 430 Watt PSU.
Don't be. I'm rocking just fine on a 450W Antec. My system is a 3770non-K@4.3GHz, full-size ATX mainboard, 16GB RAM, a HD7870, two HDDs, an SSD and an ODD. It's barely breaking 230W at full load. Measured at the wall, so it's including PSU (in)efficiency. What you want to pay attention to are how many amps you can pull from the 12V rail. Anything over 35A is fine for a single GPU system.
The only place you'd need a 500W+ unit is for SLI/Crossfire systems. Ideally you want a PSU that's rated at twice the power your system uses. Simply because most PSU are most efficient at 40-60% load. It can actually be counter-productive to choose a too high wattage PSU, because you sacrifice efficiency at low idle loads.
