- May 6, 2012
- 4,971
- 1,696
- 136
Well, curious to see how much power at what use the chip will produce and how cool it will stay with 7 security camera's attached in the system and the constant monitoring of the 7 camera's. Up till now all the pc's used got very hot at monitoring the 7 AVtech AVN363V security camera's(1.2Mpixel each). So now I'll try the APU to see if it works cooler. There is only 1 netbook in the system which always stays cool at monitoring the cams. That's a Lenovo netbook with an E350. Forgot what model the netbook is. Using a normal PC with a separate graphic card did not work out yet(has a 6450 now).Temps always go to 60C when monitoring.
This client had an AMD 965 and got a FX8320 PC delivered now.(standard dealer PC=no homebrew). He gets very nervous about high temps. He always thinks it will blow up. He tried an Intel system also but he became very nervous about the temps fluctuating so much. Its a mindset. If I tell him it does not matter he flips.
PS I will try TR@1080p with 2133mhz memory.
If you don't push the IGP too hard simultaneously, I don't think you'll have any problems. Even with the stock cooler.
