A very weird speaker problem!
Oifish
My right front speaker crackles a lot when i move use the scroll button or click my mouse. I have no clue what is causing this. please help!
I once installed some software (can't remember) that I later found caused a crackling sound on the speakers. It had me plugging/unplugging and testing the speakers for weeks before I found out. Once I removed the software, the noise was gone. It was a software (I think) dealing with xp themes, or somefink. Pretty hillarious.
Yeah - I've seen this, and often is associated with some new gimmicky software. If it just started, then it's a good case for System Restore to a date BEFORE it happened.
thats the thing i havn't changed anything software wise. I did get a new keyboard but it started like 3 days after i got the board.
S/R is still a good, easy bet. Go to the date you installed the new keyboard. It very well could relate to it, especially if it is wireless. Can you put your old keyboard back in? If so - try that. You may find the answer that way.
It's not wireless, and it was just plug and play. The problem is that I trashed the old one b/c is was in much need of replacement. Ill try changing the plug from usb to ps/2 and/or just unplugging it and see what happens then.
