- Jan 11, 2006
- 17,312
- 12
- 81
A surprising way to fix auto-correct annoyances
LOL.
MotionMan
Does your iPhone love to auto-correct to the word Id instead of if and other annoying or inaccurate suggestions when youre trying to type? Siri dictation is getting better and better, but for general typing, autocorrect isnt always a friend. Some people say that autocorrect can go straight to hell.
This trick is somewhat unintuitive, but works surprisingly well:
Use longer words.
Thats right, dont type This is a good idea. but instead type This sounds reasonable or Thats excellent.
You can even be MORE inaccurate but because there are fewer alternatives, the iPhone will guess with higher accuracy.
The longer the word, the more likely that it will be unique compared with other words in the same vicinity. Give it a try!
LOL.
MotionMan
