A question for married guys.
MichaelD
31,528
So...finding answers to burning questions like this is what keeps you up at night?
Sadness.
Roguestar
6,045
Originally posted by: dennilfloss
Originally posted by: Roguestar
Originally posted by: waitman
No, but I do.
Same here. Keep the damn crumbs out of the butter, you filthy savage.
I'm single now. I can do whatever I want with the crumbs!:D
Well, okay then. :p My ex-roommate used to do it and I'll be damned if I'm putting up with that. Ugh.
skace
14,488
7
How do you get crumbs in the butter, don't you spread it on with a knife or do you just wipe toast against the butter and then put it back?
S Freud
4,755
When using the knife you spread some on then you use it again putting crumbs from the knife on the butter or into the margarine.
Roguestar
6,045
You don't eat toast much, then?
skace
14,488
7
I have a butter dish, and you just like, slice some butter off and put it on the toast and then spread it in. I guess this is more an issue if you buy butter in a bowl products.
kranky
156
Yes, it bothers her, so I learned to take plenty of butter with the first swipe of the knife so I didn't have to go back for more.
waitman
3,758
For some reason, it just grosses me out.
Come on, those are tiny bread crumbs, not friggin' boogers.:confused:
How do you know that? My ex is pretty vindictive. Not only bread crumbs, jelly and other unidentifiable objects. :p
leftyman
7,073
I almost choked when I read your poll..this issue is one of my wifes biggest pet peeves. :D
