A question about batteries for Wavebird owners
InlineFive
9,599
Hello everyone,
I recently acquired my first Wavebird controller which I am quite pleased with. However, in the manual it says only use Alkaline and Carbon-Zinc batteries. It says I cannot use NiCad or NiMh batteries or rechargeable batteries. This is kind of a bummer as I typically use a bunch of NiMh rechargables around the house.
Does anyone know why this is? And if I found two rechargable 1.5v batteries that were NiMh or NiCad could I use those safely?
Thanks!
-Por
eelw
10,416
5,553
I don't recall reading in the manual that you can't use rechargable batteries in the Wavebird? I personally use alkalines in my Wavebird, but I know of others who use rechargable batteries fine in their Wavebirds. They have yet to experience any problems after almost 2 years now. So I wouldn't worry and just use the rechargable batteries in your Wavebird.
Colt45
19,720
WTF is a wavebird?
They probably just say that because rechargable is usually 0,2v less that normal battery.
rudeguy
47,351
14
61
been using rechargeables since I bought the thing over 2 years ago. No problems.
40Hands
5,042
Originally posted by: Colt45
WTF is a wavebird?
Wireless controller for GameCube...
InlineFive
9,599
That's what I was looking for, thanks. :) I'm assuming that rechargeables might not yield the juice to always meet the range requirements but I can deal with that.
InlineFive
9,599
You got a WAVEBIRD!!!!!!!!
It's a pretty sweet controller. If you have a cube you should definately check it out over a normal model. I bought mine from NewEgg for about $5 more then the wired controllers at B&M.
