killedradiostar
hi folks - my MSI-K8N came with its HS/F backplate mounted already. this poses a problem since i'm trying to install a zalman AlCu7000, which includes a custom backplate. is there any way to get this thing off?
Originally posted by: CaptainWafflos
I also have a Zalman fan, and you're fine using the one currently on your motherboard with longer screws, as long as you make sure you have proper connection between the heatsink and processor.
The backplate on the MSI K8T Neo is glued on. I've read about people prying it off manually without the motherboard sustaining any damage. I've also read about people heating it with blow dryers prior to pulling it off with their fingers. If you choose to use this method, just be careful.
