Tempered81
- Jan 29, 2007
- 6,374
- 1
- 81
I would get the 1066 ddrII, having owned an e8400 and ddr2 800 - I wanted to go higher than 445mhz and keep my voltage and timings per SPD, i couldn't do it with my pc2-6400
edit: per orignal post:
Imo the best standard air coolers are the:
thermalright ultra 120 and ultra 120 extreme edition
zerotherm nirvana n-120
zalman cpns9700 copper
tuniq tower
I'd lap the base of any of these 4 or 5 sinks if i bought them (just to be safe)
Yes I would slap 120mm fans all over the case you get, if it doesn't already have them, at least a 120 front/side intake, a single/dual 120 for a push-pull on your heatsink, and a 120 at the rear of the chassis for exhausting heat, or a 120 at the top for a top-mount exhaust.
Just configure to the performance/noise ratio that you prefer. the antec tri-cools or any other multi rpm speed control 120mm fans are nice.
Also with your 1500 budget, and overclocking plans, I would consider uping the gfx card from 250 to 269, and pick up that deal on the 8800 GTS 512.
stable motherboards with e8400s:
ip35e/ip35pro
p35-ds3r, p35-ds4/p, p35-dq6
blood iron/lanparty tr2
p5k deluxe wifi
tuniq tower
ip35e/ip35pro
p5k deluxe wifi
