mfenn
That Gigabyte 870 looks very nice and from looking at the specs, the only difference is that it is older and lacks onboard video. It is a good value as well. So basically, it is a cheaper motherboard but just as future proof as the 890 model. I don't really have a need for onboard video so this board would be good for me.
My reasoning behind the Radeon 5770 is that it seems a bit smaller in size compared to the 460 GTX, is cheaper and will probably draw less power. Plus I'm not a big gamer. But if there is a good deal on this board, then I may consider it.
As for the OS, which of Windows 7 versions would be well suited?
http://www.newegg.com/Product/Produc...Id=1&name=Home
I think the first one will be the most suitable since all that is needed is the CD.
Thanks.
Whaaaa??? All of the 800 series chipsets are the same age. None is more or less "future-proof" (stupid term btw). If you're going to have a discrete GPU anyway, what value is having onboard video?
As for Windows, I would get Home Premium 64-bit.
