- Jul 11, 2001
- 41,331
- 10,457
- 136
Last winter and this, I'm seeing moisture in car, evidenced by very heavy clinging fog on inside of rear window of my Mazda 626LX 1997 4 cylinder automatic coupe with less than 30k. This car is always left outside in the elements on my driveway, there's no room for it in the garage.
I thought maybe it was because the replacement windshield done just before last winter had been installed incorrectly. A rock kicked up on freeway and cracked the windshield, and I had it replaced by a cut-rate outfit (compared to others). They sent a guy out who did the job at the end of the day when it was close to dark. By the time he was done it was dark. He was probably hurrying, wanted to get home to his family. It looks OK except that it wasn't really centered, it was off by I'd say at least 1/4 inch to one side. I took the car to a well rated (Yelp) one-man shop and the guy told me it shouldn't be a problem. However, that moisture inside the back windshield made me suspicious.
This winter I have had the same problem, here in rainy season. It doesn't freeze here. Well, around 2 weeks ago I noticed moisture hanging down from the bottom of the trunk lid and figured maybe the moisture was getting in the trunk, not the front windshield.
I removed everything from the trunk, including the spare tire and there was around 1.5 quarts of water pooled under where the spare was. I got that out, and removed the carpet-mat from the entire trunk, dried it out and on recommendation, dusted the trunk (in particular the vertical surfaces) with talcum powder and hosed down the car. But I couldn't see any indication that any water was getting in the trunk. The last day it's rained some, almost 1/2 inch, and I still can't see a drop of water getting into the trunk.
What can account for all that water having pooled under the spare tire??? I can't remember a water jug breaking or anything like that. A time or two I did leave a window cracked a bit open, probably one of the two back windows, by mistake during rainy weather, but even if a lot of water penetrated, how could that reach my trunk I don't understand.
Does anyone have an idea about this? Or should I just put the now-dry carpet-mat back in the trunk (after removing as much of that talcum powder as possible from the bare metal surfaces inside the trunk), and keep my fingers crossed?
