a little math problem
Originally posted by: b0mbrman
= 100 miles / {((150 miles + 50 miles) / 3X mph)/2}
average = (a+b)/2
change accordingly and u get 3x
x is your speed. n is some coefficient. no matter what the distance travelled is, the average of your first and second half speeds must equal to 2x.
(x + n*x)/2 = 2x
x + n*x = 4x
n*x = 3*x
therefore n = 3
As your average speed for the second 50 miles approaches infinity, your average speed for the entire 100 miles approaches 2X but obviously never equals 2X.
average = (a+b)/2
(x + n*x)/2 = 2x
x + n*x = 4x
n*x = 3*x
therefore n = 3
Again, you're quite wrong.
This applies if you traveled each speed for the same amount of time, not distance.
Think about it.
average = (a+b)/2
(x + n*x)/2 = 2x
x + n*x = 4x
n*x = 3*x
therefore n = 3
You are using the wrong type of "average" (or mean). Harmonic mean, ftw!
Originally posted by: Tobolo
The problem didnt mention time. Go 25mph for two hours and then 50 Mph for 1 hour. BAM your there.
I'm thinking this is incorrect. Since the average time would not be 2x.
25+50 = 75 divide that by 2 = 37.5
<--- is bad at math.
Not sure what he was going for, but he did 100 miles in three hours. That's 33 1/3 mph.
I have no idea what question that answers...
Originally posted by: Random Variable
The distance from point A to point B is 100 miles. If you average X mph for the first fifty miles, what speed would you have to average for the second 50 miles so that your average speed for the entire trip is 2X mph?
Harmonic means. 🙂
Originally posted by: Inspector Jihad
Originally posted by: mugs
Wait, no that's not right
OK, I'm confident it's not possible. You'd have to complete the second half of the trip instantaneously.
Suppose you complete the first half of the trip in 1 hour at 50 mph. You'd then have to adjust your speed to finish with an average speed of 100 mph. You have to travel a total distance of 100 miles in a total time of 1 hour, and you've already used your whole hour.
lol, are you serious
Yep, and mugs is correct.
Some people are unbelievably clueless.
It isn't possible. Some places use this sort of question as a brainteaser during interviews.
Post your answer.
read the question wrong.
stupid question. when you say average speed, no one is thinking or cares about what amount of time you were traveling for, just the distance/time. :thumbsdown:
Sure it does. You reach infinite speed at exactly the halfway point.
.999... = 1
It takes the same time to travel twice the distance with twice the speed as to travel half the distance with half the speed. Therefore the second half of the distance must be traveled in zero time, or infinite speed.
Heres what i get
X is original speed traveled for the first 50 mi and is a rate distance/time
Tis the time it takes for the first 50 miles
So T*X=50 miles
X2 is speed traveled for the second 50 mi and is a rate distance/time
T2 is the time it takes for the second 50 miles
So T2*X2=50 miles
Add these together, we get T*X + T2*X2 = 100 miles eq(1)
The average speed for the whole trip needs to be 2X
So we need an expression for average
100 miles / (T+T2) = 2X eq(2)
Which we can solve for T2 and get 50/X - T = T2
Plug in to eq(1) we get T*X+ 50*X2/X - T*X2 = 100 eq(3)
We have an equation with infinite solution i guess
Choose Values for T and X and you can solve for X2 this shoudl always give you an average speed of 2X
For example if we choose T=1hr and X=1mph
We get 1+50*X2-X2=100 and solve for X2=99/49 mph
(if we solve eq(2) for T2=49hr)
To check we get should get an average speed of 2 so use eq(2)...
100/(1+49)=2*1
2=2
This should work for any 2 values chosen for either X1, T, or X2
Hope this helps
