A little math help..Please
happy medium
14,387
480
Symbolic
What is the length of the blue line labeled r in the image below? Give your answer in terms of a and b.
__________________
7395
And this one................
WebAssign will do simple calculations for you, using +, -, *, /, parentheses, and E-notation. For example, if a question asks for half the sum of 246 and 388, you can enter "(246+388)/2". For more complicated calculations you'll need to use a calculator and then enter your result. What is the product of 110 and 160?
Thanks,
Mr. Pedantic
5,027
Dude. In your house you have something called a computer. On it, your daughter can use something called the internet. On the internet there is a search engine called Google.
And if she's getting homework on this surely she was taught this in class?
r=(a^2+b^2)^0.5 or r=sqrt(a^2+b^2) will do it. And the second one...17600?
yes I do but its not just addition in this case
The answer is not 270
You don't know what a product is, do you?
xSauronx
19,582
4
yes 25 years ago....thanks guys.:(
fine, you havent done maths in 25 years, im not *that* surprised you dont know the pythagorean theorem
im surprised you dont know what multiplication is
im sorry that the person youre helping has severe learning difficulties
happy medium
14,387
480
Thanks you I will try these answers on the computer she is using.
This is something she got for extra credit over the summer.
happy medium
14,387
480
It is one of those questions that you think it "can't be that easy". Rather then give the wrong answer , I figured I'd ask you smart YOUNG people.
