- May 10, 2002
- 1,122
- 0
- 0
Glad to see I'm not simply losing my mind...
The other problem with Ubuntu would seem to be that they decided against having a modules.conf... instead modules.conf is made from about 5 other files... From the reading I've done it would appear you can add your code to any one of them and it should work out when you "update modules", but that doesn't seem to be entirely the case...
I found the file that seemed to be dealing with sound hardware and I added in the code that NewBlackDak provided, but it seems to no avail...
When I try (from the GUI) to run Volume monitor it tells me it could not reach the sound daemon and to run "esd" at the terminal - which, of course, does nothing for me... If I go under my multimedia configuration and "Test" the sound I get "Could not initiate test pipe" no matter if I select OSS, ESD, or ALSA for sound...
I'll check out that link you sent as soon as I get a couple free minutes, but it's off to work for now. Thanks so much for helping me out here... I sense we're not near done yet, but at least we've made some progress.
Best Wishes,
- Chaz
Best Wishes,
- Chaz
