eplebnista
I've never used anything but regular morton iodized salt (mostly on eggs and in grits).
Originally posted by: Fritzo
What, is the OP stealing Jerry Seinfeld's act now?
Originally posted by: newb111
Originally posted by: Muse
If you over do it, yes it can. It's not poison. I believe you need a certain amount of salt. Not sure about that. I met a woman who didn't salt her food, so maybe not.Originally posted by: SunnyD
Originally posted by: SagaLore
Table Salt: Sodium chloride, with a tiny amount of iodide/iodate added. It is harvested from rock salt.
Kosher Salt: Sodium chloride, identical to table salt except that iodine is not added and it comes in larger granules.
Sea Salt: Sodium chloride, with 2% iron, magnesium, sulfur, iodine, potassium, calcium, etc. in the form of other salts (over 100 different minerals). It is refined evaporated ocean water.
Hence, salt is salt. They all give you hypertension. 😛
You do need salt to live, but you get plenty of salt in the regular foods you eat, so there is no need to add it for health reasons, just taste reasons.
Originally posted by: CKent
Originally posted by: BurnItDwn
Meh, salt is too salty. I never use salt, any time a recipe calls for salt I either add sugar and/or something that contains capsaicin ...
Really? I can't fking GET enough salt. I put it on nearly everything.
Originally posted by: preCRT
You can't make crisp pickles with table salt, you need Kosher salt.
I think that may be a "wive's tale." I made jar after jar (Qt.) of crisp pickles one year with ordinary table salt. You just have to use enough of it. If you don't use enough, the pickles lose crispness in the unopened jars fairly quickly.
It's not about crispness. The additives in table salt will make the pickles dark and the liquid cloudy.
The ideal salt for pickles is canning salt, which is pure NaCl like kosher salt but fine grain like table salt. The fine grain makes it more effective so you can use less of it.
Originally posted by: Locut0s
Originally posted by: zinfamous
the other thing is that sea salt is very potent.
It actually tastes like salt. If you grew up on the iodized stuff, then that's not salt. Id' say use ~1/3 sea salt to the amount you'd usually use table/iodized.
The only good thing about table salt is that it prevents you from developing a goiter. This is actually a good thing.
That is the reason they introduced iodized salt yes. I imagine though that nowadays one would get enough iodide from all the commercial sources of packaged and processed foods that one would probably not have to worry too much about using sea salt at home most of the time.
Where do you get canning salt? Would a brewer's supply store have it? That's where I got my citric acid, which I use when canning tomatoes.
I don't agree. Iodized salt gives you hypertension, because too much iodine gives you mild hyperthyroidism.
Originally posted by: Pepsei
you guys forgot Fleur de sel, aka the top of the line salt where you can still taste the sea (it is damp). it is also very expensive.
personally, i use Maldon Sea Salt, the best bang for the buck.
It's been around for generations.
It's not like this is "new." You've just been living under a rock, or in Idaho.
Fleur du Sel > Kosher salt > Sea salt > the others
Kosher Salt for 90% of your cooking needs.
f you over do it, yes it can. I believe you need a certain amount of salt. Not sure about that. I met a woman who didn't salt her food, so maybe not.
It is a poison.
Citric acid? You mean lemon juice? 😉
Originally posted by: loki8481
I use kosher salt for just about everything except baking.
I feel like I can get more salt flavor from less actual salt.
