A good vc to pair with a 2.4ghz c2d?
toyota
12,957
Originally posted by: Schmide
Nah. You don't have to.
My point and I hope you accept it. One benchmark, or for that matter benchmarks as a whole, do not tell the complete picture.
[/quote]
well here is Warhead since its such an easy bench to run. this is the train level using Crysis Warhead Benchmark v1.2.0.0 tool. having my cpu at 2.0 and running the gpu at 655/2200 and then 460/1600 the difference is only 2 fps average and minimum in one of the most graphically demanding games out there. remember too his cpu would be slightly slower. just like in Far Cry 2 if I had a 4850 with a cpu as slow as his I would get a bigger gain at 1280 by overclocking my cpu instead of having a faster card. it would be foolish for him to get a 4890 for that low res if he isnt able to oc his cpu.
Demo: Train
Quality: High
Renderer mode: DirectX 9
Antialising mode: Off
Filtering mode: None
MultiGPU support: Disabled
Boost renderer: Disabled
Use Custom Config File: No
Random .exe: Disabled
E8500 at 2.00 GTX260 460/1800
Resolution: 1280×1024
Result(1): Minimum= 18 FPS Average= 31 FPS Max= 41 FPS
E8500 at 2.00 GTX260 at 655/2200
Result(1): Minimum= 20 FPS Average= 33 FPS Max= 45 FPS
E8500 at 3.16 GTX260 at 460/1800
Result(1): Minimum= 25 FPS Average= 36 FPS Max= 48 FPS
E8500 at 3.16 GTX260 at 655/2200
Result(1): Minimum= 32 FPS Average= 46 FPS Max= 60 FPS
