A geek joke: Why are neutron stars perverts?
Turbonium
2,157
82
degenerate is not the same as pervert.
Um, depends what you consider a pervert.
If you're inherently sexual and not shy to flaunt it, as long as you do it within socially and ethically acceptable norms, you're not a pervert.
Flashing people is not socially acceptable for example, so it's pervy, and in this case I would consider the joke as making sense.
zinfamous
111,884
31,395
but the term, "degenerate" is not exclusive to sexual forms of "immoral" behavior.
It also refers to hooligans, and thugs, or whatever. non-sexual, non-normal behavior. Meaning, there is no reason to toss out pervert, when hooligan is actually more inclusive of the "degenerate" label.
come on guys...this is not worth discussing.
zinfamous
111,884
31,395
You pull down their genes.
I laffed.
but it's actually super insanely easy because the X is a full on, complete chromosome whereas the Y is a tiny twerp of a chromosome. A degenerated X chromosome, the Y is just a stupid little "dot," compared to the big 'ol X of the X chromosome. Can be seen with very basic light mircroscopy.
smackababy
27,024
79
86
In most cases, degenerate is of an nonsexual connotation. The definition of degenerate as a noun is simply an immoral or corrupt person, neither of which could nor would be accurately used to describe a pervert in almost most scenarios. Had the joke been: "Why are all neutron stars thugs?" it would have made perfect sense. Or, had the answer been "They are flashers".
