- Sep 23, 2004
- 5
- 0
- 0
Well title says it all hehe ... here goes
Gonna get the MSI k8n neo2 socket 939
Athlon64 0.09micron 3200+
Maxtor maxline III 250GB
Chenbro Gaming Bomb case
120mm papst case fan
92mm papst case fan
Zalman CNPS 7000B-Cu cpu cooler
Corsair 2*512mb 3200xl (2-2-2-5) perhaps the pro version
3200XL http://secure.newegg.com/app/C...=1&item=20-145-522
3200XLPRO http://secure.newegg.com/app/C...=1&item=20-145-524
Seasonic 400 or 460watt psu
400w http://secure.newegg.com/app/C...=0&item=17-151-018
460w http://www.newegg.com/app/View...=17-151-008&depa=0
(allready have monitor, gfx card and the other stuff hehe)
Question 1, if i want to overclock my cpu and the ram will i need the 460w super silence psu or can i do with the 400w super tornado psu? hope to get cpu to about 2.5-2.6ghz... And ram as high as i can go and keep the good timings and stability hehe
Question 2, will the audio on the motherboard eat to much cpu power, as in should i buy a creative audigy2 card of some version and put in? (porb just a value bulk version) Comp is mainly used for gaming..
Question 3 should i buy the pro version of the corsair 3200xl to get the build in heat sinks? or how much heatsink will i need on my ram to OC it?
And last should i buy the arctic silver 5 thermal compound for the cpu cooler, or will the compound that comes with it be good enough?
Thanks in advance for the help and feedback
92mm papst case fan
